Ok, we’ll start with specs. And I know they seems odd, and I know I’m the only one to ever do this in NA (that I know of)
1994 SR20DE
Yes, that’s DE not DET, it has a distributer drive, not coil on plug.
T25 Turbo
The engine compression is about 10.5 to 1
I’m running stock 270cc injectors.
I have an SAFC installed and set up for Dec Air to correct deceleartion, and bov purge.
There’s an AEM FPR, and it’s stable at 32 ish psi of fuel
There is no IACV (yet)
the Knock is not connected (yet)
There is a charcoal canister (but that doesn’t do much anyway)
it has a 2.5 inch high flow cat
Here’s the interesting part.
The engine runs perfectly well, off a 91 KA24DE harness and ECU, the problem is as follows:
It will foul the sparkplugs, and spit nasty smelling black smoke from the tailpipe (disgusting I get complaints from everyone when I turn it on in the garage) Unless I adjust the SAFC to lo-tht -30% across rpm, and hi-tht -20% across. these are rough settings. At which point the black nasty smoke goes away, and regualr vapour from the catalityc process, which doesn’t smell at all, comes out.
Now, the issue is that with 270cc 32psi of fuel, there should be no possible way of it running piggy rich when the SAFC is at 0 across both ranges.
I was thinking MAF, but I’ve tried 3 different ones, and am preparing to swtich to my cobra.
I don’t expect anyone to have much input on this as I doubt many, if any have come across a similar setup.
thanks
