Is it common for the running lights to not work? Mine do not, is it the fuse in the box under the air intake? Is there an easy way to get at that or do I have to take off the intake? :huh:
P.S. I’ve done all the other things, car running ect. Possible the bulbs are the wrong wattage? Have to look.
Have you run the car with the emergency brake off? I know when I start my Spec, the lights stay off until I lower the e-brake handle to take off. As soon as the car detects the ebrake handle down, the DRL’s, which in my case are the headlights, come on immediately.
OK just spent another hour checking wiring and connections, fuse box has power, bulb holders do not. So, they are ugly anyways, any idea’s as to what fog lights might fit nice in those holes? Might as well put after market ones. :axe:
