Are the brakes supposd to be a bit mushy when you slam on them or should they bite and make the tires chrip?
My rotors and pads in the front are pretty worn and the rear rotors have recently been replaced. I have ss brake lines and just recently flushed the sytem. When I pump the brake pedal, pressure does build up to the point where you cannot pump any longer with only a little bit of play.
Anyone know if its just an inadequate stock braking system?Worn out pads/rotors? Possible leak?
I couldn’t hurt to check out your master cylinder. The brakes on my 200sx were a bit mushy and needed a pump to firm up even after replacing pads and rotors. After bleeding the lines a few times I found out it was the master cylinder. Replaced that and now they are rock solid.
