Kit Includes:
-3SGTE flywheel modded to fit 1uz
-3sgte pressure plate
-SR20 stg2 6-puck clutch
-1UZ to s-chassis mounts
- KA transmission adapter (Can mate KA / SR / z32 transmission to 1UZ with this adapter)
- Modded release bearing (1 inch longer)
- Pilot bearing
All the nuts and bolts required to do to swap are included. Swap is straight forward as it uses the stock transmission, transmission mounts etc.
The 1UZ is a 4.0 litre quad cam v8 that produces around 300 hp / tq N/A in the Lexus LS400 (4000lb vehicle). The 240sx weighs around 2600lbs. Do the math.
All you need is a 1UZ motorset, or a complete ls400 (which can be had for under $1000) to have this swap running. You’re getting reliable v8 fun for sr20 swap prices. If you blow the uz (unlikely), a new one is 500 bucks vs 1500 for the cheapest sr. KA trannys are 50 bucks. Was going to do it this summer, but priorities have changed causing me to sell the parts for now.
Price: $1500
Call or text 647 863 7445
Located in Mississauga, ON
