hey guys, i haven’t installed all my bushings in yet, and i don’t have aftermarket sways (YET). anyway, from what i read and asked, most aftermarket sways use the oem mounting brackets. and the energy suspension brackets are made to be used with the oem sways.
just wondering if the 2 are compatible?
thanks in advance
edit - i forgot to mention, the kit came with the sway bar end links too. i figure these would work, but if u guys know the answer 4 sure, let me know please.
the whitelines don’t use oem endlinks? they come with their own.
As far as I know, susp tech. uses oem endlinks, so does cusco. The idea of using oem endlinks seems kinda silly to me, because you are getting a thicker anti sway bar, but the strength of the endlinks is not being increased at all.
This is why I personally like the whitelines, they come with everything and are easy to install.
If you want to upgrade your end-links, you have a few options:
Go to PDM’s website and get their adjustable swaybar endlinks, which is
sold for $65USD (almost $100CAD shipped).
Or, if you notice, the endlinks are basically Heim Joints. A Heim-Joint is
similar to the pillow-ball mounts you see on aftermarket tension rods and
such. What you can try to do is find a shop/store locally that sells the
Heim-joints and try making your own endlinks.
I do believe you would need some sort of L-bracket like the ones
Whitelines come but you might be able to get away with buying just the
male heim-joint. Look at the stock endlinks and you will understand.
I’ve only found a few sellers on eBay that sell these joints.
so guys, i guess i should have been more clear. The energy suspension hyper flex kit comes with urethane sway bar D- mounting bracket (they are wrapped in metal), as well as sway bar end links (they look like 4 polyurethane wine gums, stacked on top of eachother, like the OEM ones). So, you see, I would like to get the best use out of the kit, and use all the poly urethane bushings that i have. Those bushings were made to be used with the OEM sway bar, thats why I am asking for an aftermarket sway bar that uses the OEM sway bar brackets AND end links.
sorry for not be clear the first time, and thanks for the info!!
- 24mm and 25mm Front Sway Bar Bushings
- Endlink Bushings
- Rear Sway Bar Endlink Bushings
So it only came with the Front swaybar bushings kit? But endlinks for
both front and rear? If so, then I guess these sway bushings/endlinks will
just hook right up in place of the OEM ones.
Unfortunately, the D-bushings won’t fit on aftermarket swaybars because
as Phil posted, the ST front bar is 28.5mm (and you only have a 25mm
and 24mm).
Very easy install actually. You won’t feel much of a difference from
bushing/endlink swaps on OEM swaybars. Your best shot is to save up
for aftermarket ST swaybars (which will come with the D-bushings).
BTW, I have (almost) finished installing my Whiteline bushings kit and
will post some pictures/how-tos shortly.
It’s about the journey, not the destination. In this case, the journey was
a PITA.
i’ll check the kit in the middle, i’m pretty sure the kit comes with both f and r bushing kit for sway bars (it doesn’t come with the rear end bushing though, like upper mount, rear lca, ect.).
i have access to a drill press, and was thinking of drilling out the D brackets to the thickness of the aftermarket sways (28.5mm). although the rear may be difficult, since they are pretty small. but if i get a system that comes with the hardware, i will just use that
gonad, what are you using to push out your lca OEM bushings with? a vice, or do you have access to a press? I could use the press at my work, but i don’t have the time to do it there (and they might get pissed to see a parted out nissan suspension in a honda shop). but if i can do it at home, that would be ideal.
My dad is a machinist. He has press at his work that I used for all my bushings.
I tried drilling it and hacking it out; trust me it’s not as easy as it seems,
and sure wasn’t worth the time.
If you have a heavy duty table vice, you might be able to pop the old
bushings out (and new ones in). Will require some muscle (and a pipe
for leverage on the bars). As well you will need some metal tubes/pipes
that are the size of the old bushing sleeves.
I seriously suggest you try and use the press at work. You will thank
yourself later.
Here a vice is being used to push out the old T/C rod bushing.
i did the tie rod bushing already, i figure they are the hardest. lca bushings don’t look too bad, i will mosy likely use the shop press, but i was hoping to get a 2nd set of lca’s so i don’t have to take my current suspension apart and take up a hoist at my shop all day (they won’t like a nissan in pieces in a honda shop).
