just seeing if S14 4 bolt rotors will match S13 4 bolt hubs.
Yes. There are some differences in thickness if the car is ABS or not though, you might want to check that.
i have abs. I dont know if the s14 ones are from a abs car.
you have the calipers to match, so i don’t think it would matter.
srry i wasnt clear earlier. I am replacing my S13 calipers, rotors, and pads, with S14 ones. I have the calipers and rotors. I am goin to order hawk HPS pads for the front and rear and goodridge stainless lines. I just am making sure i order the right pads for the front.(origonally i thought they were SR brakes, that would of sucked) I am goin to pull off a wheel on thursday to make sure everything will fit but im just trying to see if i can find out now.
Definently wont be a problem if you have rotors and calipers.
Sweet, in gunna go order my stuff now. Thanks alot
