How hard is it to put a s14 gauge cluster into a s13 chassis? Has anyone did it? thanks
I would say unless your really good at electronics HARD. there is the speedo which uses in the S15 a diffrent ratio, the other gauges need the proper stuff (temp gauge ect). Then there is the odometer which is electric in it and I have heard that the tach works diffrent as well.
what baout an s14 cluster. is it the same?
Again, its going to be very hard to do, lots of rewiring everything.
The S14 cluster doesnt even look that much better than the S13 so its not worth it IMO.
