Speed needle not working/half time working/not working?
  1. Is this a gauge cluster issue? Or something else like a sensor or? I need to fix this and well… you know… it’s kind of important to know at what speed you are going, plus can’t pass certification test unless it works haha.
  2. And which clusters are interchangable? Do they all fit? 180sx/240sx, US/Eur/Jap? S13/S14/S15? Skyline? Not that I will be reaching 320km/hr with the nismo cluster. What about wiring behind/fitting of cluster/etc… I also saw some digital/analog ones on sale here and there.
Just questions…
Thanks
not all clusters fit and work the same, some are digital based, some are analog, your best bet would be to get another cluster see if it works, if not, than check your speed sensor on the tranny (the biggest one closest to the output shaft on the tranny, passenger side on s13) good luck dude
wrong section.
