s14 washer fluid rez
pump / sensor burnt out…
does anyone have a washer reservoir assembly they’re parting out?
pm for quick response, thanks in advance.
Are you sure it’s burnt out? Mine just needed to have the contacts cleaned. If you push directly down on the res. And twist it a bit you may make contact. Anyway, good luck.
sorry by burnt out i mean the wires completely corroded off. at this point i’d rather just replace it haha.
