S15 Engine + Transmission
Not sure if I am going to keep this or not. Figured I would post it up here to see if anyone is really interested. I would be looking for $5000.
S15 Engine - HKS stage 2 head assembly with HKS 264 cams, 3-way valve job and port and polished
S15 Transmission - 6-speed manual, Exedy Hyper Single clutch
Custom 1-piece driveshaft (made to fit with S14)
how many km’s? 50-60 range?
I would assume that at most.
and maybe 1000km since it was built
Just wanted to add, I can also include a stand alone Power FC as well for an extra $1000.
With the right turbo this is a 400whp setup easily.
oh baby, slammin 6 gears in an S14 sounds pretty baller.
5000 with installation…deal…lol
I don’t think installation is included.
You think right Gyani
LOL
anyone that wants this would also need the S15 HLSD as well since that’s where the speed sensor goes.
To clairify, a S15 rear end is not needed for this setup.
Yes, in a stock S15 that is where the speed sensor is. That however does not mean you need that rear end.
you do installations?
what else does this transmission work with? motor wise?
No I don’t but I’m close with an amazing shop that does.
Check out www.sg-motorsport.com
I’m not sure what motor you are hinting at here but it does work with S13 and S14 SR20.
