Samsung BD-P1590: This is about a yr old and had only been used a handful of times. Non smoking/no pet house. DTS-HD and TrueHD. Internally the same as a BD-P1600 but without the annoying folding front door. Pretty clean, only minor normal handling/usage scuffs. $60
MSI NF750-G55 Motherboard: This was part of an HTPC that I built about a yr ago. Easy overclock, core unlocking, HDMI video w/7.1 audio etc. Perfect. $50
Genuine OEM 350z seatback organizer that came with my 350z. I really showed them when I turned my lease in and didn’t give them this back. New, never used it. I dunno… $20
Harbor Freight Chicago Electric sawzall & multitool(fake fein, confirmed bosch blades fit) Only used a couple times. Recently got craftsman ones as a gift. 1/2 what I paid: $20 ea
Old school Rockford Fosgate Punch 200x2: $100? (there’s one on eBay completed listings, it went for $107, mine has the elusive end caps, and you can try it out first, so it’s better. ) I have a box full of cables/wiring, take whatever you want if u buy the amp!
Specs on the board for nerds…Thought it might be a 775 socket. Damn GLWS
CPU
• Support AMD® Phenom™ II/Athlon™II/Phenom™ with AM3 package.
Please refer to CPU Support for compatible CPU; the above description is for reference only.
Hyper Transport Bus
• HyperTransport 3.0 supporting speed up to 5200MT/s
Chipset
• NVIDIA® nForce 750a SLI single chipset
Main Memory
• Supports Dual DDR3 800/1066/1333/1600 (OC)
- 4 DDR3 DIMMs (240pin / 1.5V)
- Supports a maximum memory size up to 16GB.
Slots
• 2 PCI Express x16 slots with x16 operation (PCI Express Bus SPEC V2.0 compliant)
• When 2 PCI Express x16 slots are all installed, the PCIE x 16 lanes will auto arrange form x16/ x0 to x8/ x8.
• 2 PCI Express x1 slots
• 1 PCI slots, support 3.3V/ 5V PCI bus interface.
On-Board IDE
• One IDE port by NVIDIA® nForce 750a SLI
- Supports Ultra DMA 66/100/133 mode
- Supports PIO, Bus Master operation mode
- Can connect up to two IDE devices
On-Board SATA
• 5 SATA II ports by NVIDIA® nForce 750a SLI
• 1 eSATA II port by NVIDIA® nForce 750a SLI
- Supports storage and data transfers at up to 3Gb/s
RAID Function
- SATA II 1~5 support RAID 0/ 1/ 0+1 /5 or JBOD mode by NVIDIA® nForce 750a SLI
MSI Reminds You...
• The RAID setup floppy disk is optional depending on the districts. You can download the files from the website to make the setup disk.
Audio
• Chipset integrated by Realtek® ALC889
- Flexible 8-channel audio with jack sensing
- Compliant with Azalia 1.0 Spec
LAN
- Supports 10/100/1000 Fast Ethernet by Realtek 8211CL
Internal I/O Connectors
- ATX 24-pin power connector
- ATX 4-pin 12V CPU power connector
- CPU x 1 / System x 3 FAN connectors
- CD-in connector
- Clear CMOS jumper
- Power button
- Chassis intrusion switch connector
- Front panel audio connector
- Front panel connector
- Serial port connector
- 3 x USB 2.0 connector support additional 6 ports
- 1 x Floppy disk drive connector
- 5 x Serial ATA II connectors
- 1 x ATA133 IDE connectors
- 1 x SPDIF-out header
- 1 x TPM module header
- 1 x OC Switch
MSI Reminds You...
• The floppy disk cable will be optional.
Back Panel I/O Ports
- 1 x PS/2 keyboard
- 1 x PS/2 mouse
- 1 x 6 in 1 audio jack
- 6 x USB 2.0 ports
- 1 x RJ45 LAN jack
- 1 x eSATA port
- 1 x DVI-D port
- 1 x Graphic Card port
- 1 x HDMI port
Dimension
• 30.48cm(L) x 22.38cm(W) ATX Form Factor
Mounting
• 6 mounting holes.
