I think Bero (Brian) has that seat. From what i remember he customized the stock rails for his s13.
From what i could tell it was WWWWAAAYYYYY more cmofortable than his sparco.
Although i could not really fit in either of them.
It’s a great seat, buy it if it’s cheap…but seeing how you’re a bit bigger than me it will probably be a little too tight. Sit in it first if you have the chance.
customizing your stock brackets is a complete bastard…
when i put my seats in (bings brides) i broke down and bought a pair of sparco universal bottom mount brackets. I’d guess they will fit that see as well, seeing as its bottom mount.
they have bride rails for eveyr application side mount get FG bottom mount get MO. expect to pay an arm and a leg for them though. the guys on zilvia are raving about nagisa auto rails for side mount… check those out as well. usually reclineables are bottom mount. fixed seats are side mount. i tried the custom fab route with pavel. wasted a day to no avail. just buy the proper bride rails but budget your purchase.
I have the Corbeau Forza II (wider version in the shoulder then the normal Forza ) used them for years… they are better then the Sparco for the simple reason that they are sprung AND webbed seat and back… this makes a workd of difference when your street driving, the rails are very good, smooth mechanisim and the total seat/rail setup is ~ 25 maybe 30lbs if your seat rail is bigger.
Anyone got the Bride rails in an S13 I can try out? I also am small, and pretty much the only reason I didn’t get proper rails was because of that. I kinda want to be able to see over my dash
Are there any bottom mount options though? My zeat is teh bottom mountz. Maybe I’ll just get another seat, seen.
