Someone to tow my beloved conversion van from utica,ny to buff $250 cash
On my way back from vacations at the relative…the 1995 ford e150 conversion van decided to die on us. Out of the blue engine shuts off and no start after that still cranks but no fire. Its the ford inline 6 300ci motor.
I need someone to do it tomorrow or asap. Let me know if anyone can do it.
Text me asap if you can help. 716 903 6606
cant help you on the tow but…
you most likely have a short to ground on your coil, your coil has gone bad, or you have bad primary wiring. connect a volt meter to both sides of the coil and check for voltage, you should get 6 volts that turns on and off when the truck is cranked. on the side not connected to the points (plus side) you should have 6 volts when the key is on. on the other side of the coil you should have a ground that turns on and off when the points open and close. if all of this is OK then you need a new coil $20-$30. if you want to check the coil remove the coil wire and both primary wires. check if either primary side has conductivity to ground, if it does your coil is bad.
pm zero5672 he might be willing to pick this job up as he was telling me if i ever got a car out of state he would tow for a fee and he has a trailer…
Does this thing really weigh 7200 Lbs??!!
No more like 5900lbs from what title says
---------- Post added at 04:32 PM ---------- Previous post was at 04:00 PM ----------
if you need a flatbed, I have guy. he wants more than 250 tho
its not on the 90 is it?
400 mile trip
11 mpg
36 gal of gas
3.15 per gal
12 in tolls?
~127 cost just in fuel for my truck to go get it
250 - 127 = 123 for 8 hour drive, loading a van that doesnt run on my trailer. driving through the snow/crap.
sorry but def not worth it
No not on 90, its about 1min off exit 31 (utica).
Dave, how much is he looking for? And what’s contact info?
you still have the same number? 6606? Ill send you the info or text me 903-4502
Can’t you get AAA for less?
So new updates!
Car has a broken timing gear some teeth missing
Anyways, The car is now only 100miles from home.
its a round trip of 3hr and 200miles.
let me know if anyone can do it. thanks.
I thought you would have found someone to do this by now.
