Saw this on reddit yesterday. I usually drive as close to them as possible… really helps my MPG.
:tup:
This is why you ride under them. Didn’t you guys learn anything from Fast and the Furious movies?
This is why I drive an SUV :tup:
Just don’t be stupid and you won’t have said issue. I’m sure an SUV would still result in a shitty day if you hit it hard enough. I can’t imagine being so fucking stupid that a semi out brakes me and I hit it. Or don’t see it and I hit a stopped semi.
Lesson of the day:
Make sure you are following DIRECTLY behind the semi to avoid death and maximize slipstream-induced mpg.
I have the reflexes of a cat so this is meaningless for me.
:tup: those crashes were brutal though. interesting to watch for sure
Impact force is based on the speed differential. Draft properly folks.
Was that a Corvette?
appears to be.
LOWER IT!
i’m just glad that testing like this is done at all.
+1 to humans that do things that help other humans.
My friend and his wife passed away in an accident like this. Closed casket. I give semis all the space they need.
years ago before my turbo SHO was turbo I almost slammed into a semi in a construction zone. I remember watching that bar on the trailer go way up my hood but because my car was low and I was 100% brake I never made contact with it. I was shitting bricks after that moment, and have never put myself in a situation like that since. This was probably in 2004 i would guess. it was never a thought in my mind that the A pillars would have been the first significant contact point then my face.
I just want to point out that they crash a lot of chevys to make that video.
This is why I own a Miata.
Pure reason.
Checkout the bolts snap at 1:20.
I almost had a Honda go under my truck last Saturday on 219 but he swerved at the very last second.
---------- Post added at 06:57 PM ---------- Previous post was at 06:53 PM ----------
Typically if you hit the side you will be swerving at an angle which would totally change the impact.
I don’t know if I’d go so far as to call him a lucky bastard. Look where the bar is. Right in line with his body.
