spacers and extended wheel studs
Hey guys, just wondering if it is safe to run 8mm spacers without extended wheel studs?
depends on how many threads you can turn the lug nuts… probably not but only you can prevent forest fires
not on stock S13 4 lug… dont run more than 5mm.
100-7708 is the ARP part number for extended studs for S13 all around… changes thread pitch to honda 12 x 1.5mm though
Problem is that I want to run a set of bolt on spacers for another set of wheels that I have. I’m just worried that that extended studs will be too long to use the bolt on spacer.
i got 4mm spacers and that was stupid scary, i stripped one or two lugs bec i could hardly hand tighten them. It was like $30 for 8 longer studs and nuts at napa.
so im assuming that the wheel studs are longer on an s14 than on an s13 by the statements noted above?
Race Ready has extended wheel studs for a great price AND they use Nissan thread pitch!
I bought peak-performance studs from pdm-racing.com but they were twice the price as our vendor.
