Hey guys what’s up.
Well I’ll be putting these new wire’s in today and I will let you know my opinion tomorrow if there’s a noticeable difference. Thanks to Phil and JDM Place for these.
Here’s the low down on them though.
Thickness - 9mm
Outter Cover - Premium 100% Pure Silicone tempered outer jacket. Superior protection against chemicals, heat, ware and abrasion; provides tighter terminal grip for superior terminal protection. Overall flxibility and rigidity of the wire make it easy for installation.
Second layer - Premium Fiberglass Braided Inner Jacket adds another level of flexibility strenght and protection.
Third layer - Premium 100% Pure Silicone Inner Insulation for unequalled dielectric strength barrier prevents arcing and voltage leaks.
Premium Latex Silicone Bonding Layer - Enhances core stability and maximum voltage conductivity.
Triple MAG core’s - Are in each wire which dramatically reduce both electrical resistance and heat generated in all wires, at any RPM.
Supposedley these wire’s provide 20x the ignition power over OE spec wires and twice the power over performance wires. Apparently these provide consistent spark all the way through your RPM band. The result is a gain of power, improoved combustion efficency and better fuel economy.
I will also be using NGK G Power Platnium sprak plugs with these so all in all if this is true, I should feel a small difference. At least I hope.
So as I said I’ll let you know.
Take care everyone.
Easy 8)
