With all of the E30 talk lately I figured I would take a couple cell phone pictures of my mother’s car.
She passed away 2 years ago and my father has been bombing around in it ever since.
The car has never seen snow and rarely sees rain.
The odo just flipped 87,000 miles.
It is autotragic unfortunately.
The car is all original except the top.
Her winter car was the 325IX that I purchased from her before she purchased her A6 Avant for winter months.
Edit: The little things you see on the doors are nautical flags that represent my parents initials, they enjoyed sailing.
clean clean,
Are you going to pave your driveway or just rely on quattro to get through it in the winter?
not to be that guy but, price?
Nice :tup:
… That wooden gnome is creepy as hell…
Thanks.
I might pave after I win th lottery.(1400ft long)
It’s not for sale, I just wanted to show another clean E30.
Thanks and thanks.:biglaugh:
Word of advice; Don’t drink all day at the fair when they are going to auction off chain saw carvings that night.:lol:
The money went to a good cause though, America’s Erie County Fair Agricultural College Scolarship Fund.(Say that 3 times fast.)![]()
Your driveway is almost 1/4 mile long, make it an 1/8 drag strip
by the looks of your house im sure you dont have to win the lottery to pave your driveway
Believe me I have thought about it!
The first 1/8th is flat and the second 1/8th is up hill which helps in stopping.
I don’t think the neighbors would be to happy though.![]()
I is house po.
BUMP for e bay picture.
Check out this M3.
I guess a museum might pay that much…:jawdrop:
ugh, that m3 is about at as clean as yours! so nice!
I need to get one of these for my new car. I purchased my mom’s (then dad’s) BMW from the estate. Sentimental reasons mostly but my first vert will be fun I am sure.
I keep getting the itch for another e30 myself. theyre so fun.
Nice I really enjoyed having the convertible this summer. Ill miss it next summer
and sorry about your dad
Thanks.
It is fun but I think the vert E30 weighs about 500lbs more than a M3. lol
My Ferd F250 could tow this thing to 60mph faster! lol
ENGINE/TRANSMISSION
M20 2494cc SOHC belt-driven inline 6, 2 valves/cylinder, cast crankshaft
168 hp @ 5800 RPM
164 lb-ft torque @ 4300 RPM
Compression ratio: 8.8:1
Bore/stroke: 84x75 mm
Bosch Motronic 1.3 fuel injection w/ DME
Exhaust control: 3-way catalytic converter with Lambda sensor
5-speed Getrag 260 (manual)
Ratios:1 (1/2/3/4/5/R): 3.83 / 2.20 / 1.40 / 1.00 / 0.81 / 3.71
4-speed ZF 4 HP 22 (automatic)
Ratios:1 (1/2/3/4/R): 2.48 / 1.48 / 1.00 / 0.73 / 2.09
Final drive: 3.73:1
4.10:1 (325iX) also has center differential w/viscous coupling,
27%/63% f/r torque split
CHASSISM
Front suspension: MacPherson struts, coil springs, lower control arms, swaybar
Rear suspension: Semi-trailing arms, progressive rate coil springs, swaybar
Steering: Rack and pinion, power assist
Steering ratio: 20.5:1
Front brakes: 260mm ventilated discs
Rear brakes: 260mm discs
ABS standard
14x6.0 alloy wheels on 195/60HR14 tires
14x6.5 alloy wheels on 195/65VR14 tires (325is)
15x7.0 alloy wheels on 205/55VR15 tires (325iX)
DIMENSIONS
Wheelbase: 101.2 inches
Weight distribution, F/R: 53%/47%
Fuel capacity: 14.5 gallons (1987, 1989-1990)
16.4 gallons (1988)
Curb weight: 2811 lbs (325i 2-door, all years)
2850 lbs (1987 325i 4-door)
2813 lbs (1987 325is)
3015 lbs (1987 325iC)
2895 lbs (1988 325i 4-door)
2865 lbs (1988 325is)
3055 lbs (1988-1990 325iC)
3010 lbs (1988-1990 325iX, 2-door)
2844 lbs (1989-1991 325i 4-door, 1989-1990 325is)
3054 lbs (1989 325iX 4-door)
3050 lbs (1990 325iX 4-door)
2988 lbs (1991-1993 325iC)
2955 lbs (1991 325iX 2-door)
2999 lbs (1991 325iX 4-door)
PERFORMANCE
0-60 mph: 7.7 seconds (325i manual)
7.9 seconds (325iX manual)
1/4 mile: 15.9 seconds (325iX manual)
Top speed: 136 mph (325i)
127 mph (325iX manual)
130 mph (325iC)
Skidpad, lateral g: 0.77 (325iX manual)
Slalom: 63.7 mph (325iX manual)
EPA fuel economy, city/hwy: 18/23
- Updated - - -
Interesting powa numbers if you compare…
325 (1988 “Super Eta”)
ENGINE/TRANSMISSION
M20 2693cc SOHC belt-driven inline 6, 2 valves/cylinder, cast crankshaft
128 hp @ 4800 RPM
170 lb-ft torque @ 3200 RPM
Pics bro, pics.
I noticed my original pics are gone. I will get pics with the updated wheels.
yes, new pics are needed.
and you should just s50 swap it, cheap and easy, a lot easier than 6 speed swapping an rs6
A pic from a couple years ago. I will get better ones soon.
