spider gears
HAs anyone ever welded spider gears on a rear end to make a solid axle?
Does not work well. We’ve done this in derby cars before.
why? call jj’s in the morning and ask for brian. i bet he has a posi and probably gears too.
The ol’ lincoln locker. It’s been done before.
If you have the cash, a limited slip is x827364827346193496173467981234 better
thinking about a mini spool
welding spider to pinion shaft = gears cracking and falling into R&P.
get some axles out of a 89 & ^ s-10 that are 28 spline instead or ur 26 splines!
