i win 3 inch down pipe 3 inch gutted cat 3 1/4 inch exhaust.
mines tuned ecu. if you know anything about these they arent kind on gas at all.also stone cold. failed by 60
luckly it was just the test at school
wow… looking at all of you guys’ limits i should’ve done mine under hot rod i would’ve passes non problem if that had been the case. i asked the guy who did my e-test about hot rod setting and he said the limits wouldn’t change that much. how did you guys get them to test your car under hot rod? Cause i passed everything under being tested as a ka except the nox readings limit was 350 or something and my reading was 1560.
i plan on etestin my sr 240 next week
i have a 3" downpipe with 3" hi flow cat and dunno wat size exhaust
do i just ask the guy to run it under hotrod specs or what
wat do u guys think?
i gotta get my car e tested as well if find a cat 3inch for cheap ill take it to a shop i used to work at and put it on practice mode to see how it does if it passes ill do it in the regular mode if it doesnt thennn i shall do it another way.
