Could someone do a small write up for me on all parts i would need to reuse on an sr20 off my ka24e?
heavy throttle i s fairly comprehensive. Your engine harness, if you have ABS. your afm if you don’t have one for the s13 sr. that’s about it to save from your old engine.
Keep the motor mounts (just in case the sr ones are broken), maf sensor (keep it around, it’ll work with the sr and you never know when you or someone else may need one), wiring harness (need a length of this to extend sr harness to work with lhd car) and all the main vacuum hoses (can never have too many vacuum hoses haha). You may also want to remove all the tranny sensors and lower harness, if the sr doesn’t come with it’s own.
what about all the wiring around ur fan shroud n stuff like that ??
