SR20 rear transmission seal same as KA?
the rear seal on my SR20 transmission is leaking a bit. i’m talking about where the drive shaft goes into the rear of the transmission. it’s a blacktop S13 SR if it makes a difference.
does anyone know if this is the same as the seal from the KA? the transmissions are very similar so i imagine they are the same, that would make sourcing one out fairly easy. if it isn’t, would you happen to know the OEM part number for it?
thanks in advance.
At CT, the rear tranny seal is $5.13… $5 is worth a shot?
Yes it is.
perfect, thanks!
