sr20 swap on an 93 altima help!!
Installing an SR20 in my 93 altima…getting everything from here
https://www.tigerjapanese.com/product_info.php?cPath=44&products_id=151
A JDM SR20 DET ENGINE WITH FWD/AWD 5SPED TRANSMISSION
Item Description
• IMPORTED FROM JAPAN
• Make: Nissan
• Engine Code: SR20 DET
• Year:
• Valve Train: DOHC
• Horse Power:
• Transmission: FWD/AWD 5 Speed
• Torque:
• Redline:
• Displacement:
• Mileage: Approximately 25-35 Thousand Miles
• Condition: Best
• Included: Complete Motor
Complete Head & Block
Distributor, Intake Manifold
Exhaust Manifold, Alternator
Power Steering Pump
Fuel Rail, Injectors
Throttle Body, ECU
5 Speed Transmission, Starter
Wiring Harness, Turbo
will this work and what else do i need?
The U13 Bluebird in japan and the U13 altima in north america are the same chassis, that motor probobly came from a bluebird, if you’re lucky, the altima crossmember might work with bluebird’s AWD transmission, if not, you might be able to use a FWD SR transmission like a G20 and the G20 crossmember, which would be lighter then the AWD trans. look on wikipedia or call the guys at JGY Customs, they know everything about SR’s
http://www.jgycustoms.com/
Terry
