I have been looking all over the net for an answer to this but can’t find anything. This is for those who have experience building an SR20. I am installing new cams right now and I have the old cams out. The chain is hanging as the FSM states. Is it possible that the chain can come off the crankshaft gear while its hanging or is there not enough clearance for it to come off.
The counting method is 100% correct 100% of the time, just make sure you take your time and do it right. 1 tooth is like 10 degrees of timing. It’s the difference between your car starting and not.
