This is the Parts List for the individual items that make up the engine rebuild gasket set for the S14 “Black-top” if anyone needs it (taken from the packing list inside the kit I got).
10101-69F25 (SR20DET) Gasket Kit - Engine Repair
Part# Description Qty.
KP710-00150 Gasket sealant - F.I.P. (150g.) Qty. 1
11026-01M02 Washer - drain plug Qty. 1
11044-65F03 Gasket - cylinder head Qty. 1
12279-18V00 Oil seal - crankshaft rear Qty. 1
13079-2J200 Gasket - chain tensioner Qty. 1
13207-D0111 Oil seal - valve exhaust Qty. 8
13207-84A00 Oil seal - valve intake Qty. 8
13270-65F00 Gasket - rocker cover Qty. 1
13271-65F00 Gasket - rocker cover Qty. 1
13510-53J10 Oil seal - crankshaft front Qty. 1
14032-65F00 Gasket - collector intake Qty. 1
14035-78J01 Gasket - intake manifold Qty. 1
14036-53J00 Gasket - exhaust manifold Qty. 1
14415-17M00 Gasket - turbo charger inlet Qty. 1
14445-79E00 Gasket - turbo charger outlet Qty. 1
14465-79E00 Gasket - inlet tube air Qty. 1
15053-1E400 O ring - oil strainer Qty. 1
15066-0M300 Gasket - oil filter bracket Qty. 2
15066-77A00 O ring - seal Qty. 1
15189-40P00 Gasket - eye bolt Qty. 2
15189-69F01 Gasket - eye bolt Qty. 4
15196-69F00 Gasket - oil tube outlet Qty. 1
15270-D0103 Gasket - oil filler cap Qty. 1
16175-65F00 Gasket - throttle chamber Qty. 1
16618-10V05 O ring - injector upper Qty. 4
16618-10V10 O ring - seal Qty. 1
16618-53J00 O ring - injector lower Qty. 4
22131-50F00 O ring - support distributor Qty. 1
23785-54C00 Gasket - A.A.C. valve Qty. 1
23785-65F00 Gasket - A.A.C. valve Qty. 1
