SR20DET "Red-Top" Engine Overhaul Gasket P/N's
This is the Parts List for the individual items that make up the engine rebuild gasket set for the S13 “Red-top” if anyone needs it. You can order the individual gaskets from your local Nissan dealer.
10101-50F27 (SR20DET) Gasket Kit - Engine Repair
Part# Description Qty.
KP710-00150 Gasket sealant - F.I.P. (150g.) Qty. 1
11026-01M02 Washer - drain plug Qty. 1
11044-50F01 Gasket - cylinder head Qty. 1
12279-30P00 Oil seal - crankshaft rear Qty. 1
12279-1E000 Oil seal - crankshaft rear (alt#)
13079-53J01 Gasket - chain tensioner Qty. 1
13207-D0111 Oil seal - exhaust valve Qty. 8
13207-D4201 Oil seal - intake valve Qty. 8
13207-84A00 Oil seal - intake valve (alt#)
13270-52F00 Gasket - rocker cover Qty. 1
13270-53J13 Gasket - rocker cover Qty. 1
13271-52F00 Gasket - rocker cover Qty. 4
13510-53J00 Oil seal - crankshaft front Qty. 1
13510-53J10 Oil seal - crankshaft front (alt#)
14032-52F00 Gasket - collector intake Qty. 1
14035-53J00 Gasket - intake manifold Qty. 1
14035-53J10 Gasket - intake manifold (alt#)
14036-53J00 Gasket - exhaust manifold Qty. 1
14415-17M00 Gasket - turbo charger inlet Qty. 1
14445-26E00 Gasket - turbo charger outlet Qty. 1
14465-79E00 Gasket - inlet tube air Qty. 1
14465-50F00 Gasket - inlet tube Qty. 2
15053-1E400 O ring - oil strainer Qty. 1
15066-77A00 O ring - seal Qty. 1
15193-P9000 Gasket - oil tube inlet Qty. 2
15193-03E00 Gasket - connector water Qty. 6
15196-79E00 Gasket - oil tube outlet Qty. 1
15270-D0103 Gasket - oil filler cap Qty. 1
16175-79S70 Gasket - throttle chamber Qty. 1
16618-10V05 O ring - injector upper Qty. 4
16618-10V10 O ring - fuel rail seal Qty. 4
16618-53J00 O ring - injector lower Qty. 4
22131-50F00 O ring - support distributor Qty. 1
23785-50F00 Gasket - A.A.C. valve Qty. 1
Mods - can you please sticky this post??
Done.
I do not see that Gasket number for the one that goes on the water line in from rad. the 3 bolt one for the Thermostat
use a high-quality liquid gasket
Ya that is what I was going to do, but I thought I would ask, sometime it is just nice to have the real thing
bing FTW
I am going to assume this in the Front main gasket?
Front Main Seal is the same as the KA24DE buddy… so you wouldnt even have to provide a SR part #, just tell them you want one from a 91+ 240.
The Rear Seal however is not the same and you will need the correct #. Either way, I have both correct #s @ home since I’ve changed both front/rear main seals so I’ll forward you the correct #'s later tonight just incase :wink:
Thanks Brother.
My Rear is just fine but ill take the number just incase
that would be the number for all the gasket, seals ,etc?
Would it be a good idea to do all of them on the SR?
