just wondering if this is normal for the sr. on cold start my car runs at 2000rpm and stays there until the temp gauge is in the middle, then it settles down to 750. normal? the ol ka used to run at 1500 for a couple seconds then settle down.
mine kicks over and immediately runs at 1500 or so. no high revs, and no drops
2000 rpm then gradually goes down to 800 ish
mine runs around 1500rpm on cold start and gradually goes down as the temp starts to rise and will settle at 800rpm when the temp is in the middle.
well mine starts up from cold at 2000 for the first 5-10 seconds then 1500 rpm till it hits 1 bar heat, then 1000 till 2 bars, then 800-850ish idle.
hits 2000 briefly and drop its to about 1500/1600 then slowly works its way down
pussys, no IACV is where its at.
2500 rpm, have to feather throttle while engine is cold.
