does anyone know if a steering wheel hub from a R32 will work in a S13?
Pretty sure all nissans are the same. S13 worked fine on a Z31 so I wouldnt think nissan would change it from a Skyline. The only thing that is different is the horn setup. Skyline is wires and S13 is a contact point. Not sure if that makes a difference with just the hub. There should be a part you can bolt up easly.
Yeah, they should be very similar, if not the same. My bro used an S13 hub on his R32. He just took off the contact point part on the end to make it fit and used the wire for the horn…
