I have acquired tons of parts. Getting rid of the inventory.
IF THERE IS ANYTHING YOU NEED THAT’S NOT LISTED, ASK. I have a TON of parts, its difficult to post them all. No matter how small or strange.
I tried to get pics of as much stuff as I could. I’ll see what I’m missing and try and get more.
2005 STI Shell. This would be perfect to buy a wrecked STI and transplant the drivetrain into this. You could have a rust free sti for well under 10k if you get a good donor.
-<100k miles on it.
- NO RUST.
- Clean title, never wrecked.
- 6 point custom cage
- gutted rear doors
- around 2900lb competition weight
- Price depends on what parts you want
- Can come in different states, from a bare shell to a roller.
STI drivetrain - 102k miles - Preference given to whoever wants the full swap. This would be perfect for a bugeye owner who wants an STI drivetrain. (Willing to split the trans/diff for the right price). $4800.
- 6-speed
- rear diff
- driveshaft
- axles
- hubs w/ ARP studs
- brembos
- stock sti struts with eibach springs
- rear subframe w/ sti lateral links (bolt from hell has been replaced, new oem bushings).
- front subframe with sti control arms and sti steering rack
4x STI coil packs 100
ACT HD 6 puck clutch 400
Injector Dynamics 2000cc Injectors 600
killer B oil pickup 150
Single Dunlop direzza z2. 245/45-17. BRAND NEW. $80
OMP TRS XL seat. This is 2 months old, ended up ponying up the dough for sparcos. FIA rated, expires in 2019 300
Sparco Corsa seat w/ side mounts. This is a real seat, not a replica. There is some slight sagging to the back cushions but no noted wear. $400
Ultimate Racing Rotated turbo kit (Jethot coated) $1800
– BRAND NEW Garrett GT35R turbo CHRA
– Rotated up pipe/downpipe with recirculated EWG
– Tial 44 wastegate
– Cold air intake
http://www.ultimate-racing.com/xcart/product.php?productid=30&cat=47&page=1
STI heads w/ all manley valvetrain. These do have some slight scoring in the front cam journals, but I wouldn’t hesitate to clean them up and run them. 500
KOYO radiator - this is not made anymore and was the best radiator available 230
silver GC impreza hood scop 45
2x sti oil dipstick 10
[B]sti starter 30
2x sti oil fill neck 10
sti crank pulley 40
water pump inlet 10
ac pump bracket 10
misc evap hoses offer
used sti pistons, rods, wrist pins, clips 50
stainless coolant reservoir 40
wrx gas tank straps 25
GD rear decklid carpet thing 20
2x cowl covers -plastic behind windshild wipers 15
almost new sti t-belt tensioner 30
sti oil pump - 500 miles 40
outback motorsports alt relocation kit 60
sti coolant crosover pipe 45
various coolant lines offer[/B]
block thing on front of motor 10
interior parts offer
AC lines 50
02 wrx front subframe,steering rack 150
02 wrx steering column to rack joint 15
05 sti seat belts 20
sti emissions stuff offer
2x sti motor mounts 30
sti trans mount 30
2x 02 wrx center console 50
STI timing cover set 75
4x almost new nitto nt-01 tires 255/40-17 400
sti dash airbag 15
GD rear strut tower brace 25
Wrx brake booster 40
Wrx clutch master cyl 40
Wrx pedal box 40
Wrx power steering lines 50
JE oil scraper rings - NEW 20
2011 wrx flywheel 50
[B]AVCS solenoid internals 40
sti valve springs and retainers oem 35
various timing components offer
2x used sti water pump 15 ea
Used CP Pistons 60
Unknown brand Big Maf with sensor 50
JE rings 99.75 - NEW 55
2x rear timing covers 35
2x sti valve covers 45
2x AVCS cam pulley sets 150
AEM map sensor 80[/B]
Ferrea valve spring retainers - used 100
sti oil pan/baffle 50
