looked at what i was told to be a 180sx rear subframe. however it had stock 5 bolt hubs and the axles were 6 bolt. the sway bar was also a different shape, instead of a loop, it had a different bend. did any 180s ever come with this setup? brake calipers said L K 32 on them. could this maybe be a R32/R33 rear subframe? is an R32/R33 rear subframe compatible with a S13? will it fit in without any modifacations? is the R32/R33 a better subframe then a stock 180? comes with diff also. is what i saw actually a 180sx rear subframe?
180sx axles to diff are 5 bolt.
take better pics…
Looks like S13 calipers to me dude.
6-bolt is NA. Perhaps someone converted the subframe to 5-bolt.
Less work = hooray for you?
measure the width
done deal.
pictures are from my shitty phone
take a pic of the diff the uprights and the plave where the diff bolts in … does the diff take 2 bolts or 4 bolts on the diff cover?
i couldnt check. it was covered in other parts and the guy was busy and didnt want to take it all the way out for me.
