i bought a used eibach sway bar, and it didn’t come with the bushings to mount it. i called eibach, but i was on hold for over 30 minutes and gave up, will another type fit, or is there a way to get it to mount without them??
try ebay?
your stock ones fit???
which ones, the endlinks or the ones the sway sit in? Usualy you can find Energy ones as replacements, pepboys sells ES endlinks if you need them.
check out Energy Suspension Parts.com, they may have one that fits your needs.
and yes, you need bushings for the swaybar.
