I was going to be using this in my s13 for my V8 swap but have changed my mind and am now going a different route.
This transmission came out of a 1994 Pontiac Firebird with only 40,000km on it
1993 and 1994 were the 2 years the T56 were built the strongest to date.
This transmission sells anywheres from $1500 to $2000
(if you can even find one from these years as they are known to be the best years ever built)
I am asking $1500 for the transmission and will deliver!!!
Well thanx for the info but this was the stronger for the fbodys.
these trannies are listed for 1500 with 100,000km or more and this one only has 40,000
Negative. Do you really think they would put weaker gears in the transmission used in the vehicles that makes by far the most torque of all the applications? Viper Spec T-56’s are by far the strongest of the bunch, especially the 04-05 version that crossed over internals with the SRT-10 Ram. All 03-06 Viper T-56’s have a 1-piece counter-shaft rather than 2, eliminating the main weakness, but the 04-05’s also have a 9310 1-4 gearset to hold up in the heavy truck application.
