Selling my tomei 2 way clutch pack lsd I bought in the spring. It’s in an s14 non abs housing, has jdm 5 bolt input shafts with 5 bolt axles included. I’m pretty sure you can just use the Canadian 6 bolt input shafts in place of the jdm ones if you don’t wanna deal with swapping axles. And if you’re looking to install it on s13, you can either swap over the pot itself, or just change the rear diff cover and you’re golden (It was intended to be installed in s13). Aside from that, I am not sure if it has a tuned final drive, but if it does, then it’s bonus for you.
$650 out the door. I’m in markham
sam
