i just picked up a LE stage 3 heads and a stage 1 cam and a few other engine things, i have a aftermarket torqure arm but thats all, anyone no of any good trailing arms that are nice that arn’t 2 or 3 hundred dollars? i seen a few off brands on ebay for 70 to a hundred bucks but i don’t know if there scrap or not. i also have 3:73’s now.
spohn
x2 brian can hook ya up !!
some big heads for a little cam
but ya spohn or UMI i had UMI and i loved them…and heard nothing bad about spohn and Brian will hook u up!!
All I see around here are spohn. Seems to work well.
i got some used hockins,bmr shit here
how much
and i meant stage 2 heads, not that it matters
which ones
sweet!!! a fellow member here Jeff95T/A has the same set up…belive he ran a 12.5 to date
Can’t wait to see how you like it. You get any other stuff to go with it?
doesn’t matter
i have a fair amount of bolt on’s but i have to figure out a stall and whare to get to the pcm reflashed. even if i get somewhare in the 12’s i’ll be happy.
a friend of mine picked up a golen 383. anyone know if there any good? emage performane is just finishing it up.
golen is supposed to be a very good engine builder…but there heads and cam arnt the best out there
I got mine done by PCMforLess. Bryan did a great job, especially for mail order - fired up first try, idle is good, A/F ratio looks good.
Might want to consider 30 lb/hr injectors if you haven’t done that.
