ok so i was doin a few burnouts and then i stopped and everything was good. As soon as the light was green i just went normal and i was kinda in gear but then just high revs and no go. So i shifted to second and same thing. Then i stopped and started again and it was all good…then it started again…high revs and no go.
But from what you’ve written, it sounds like you’ve got a manual tranny that has a slipping clutch due to overheating/abuse/age etc.
Let it totally cool down, drive it the next day and try pushing it in the higher RPM’s a bit. If you start revving higher without gaining speed then your clutch is slipping. If it connects fine, you may have just overheated it during your burnouts…
ok well i woke up this morning and everything seemed to be normal again…so should i still get it checked out or just praise the lord that my car running awesome and drive it like normal.???
