Kinda long… cliff notes at the bottom.
Some history first. Some know it, some don’t. My Evo 9 had it’s first round of mods last year after I met Justin, JVG, and Adam and they helped me come up with an initial build, which consisted of:
Injen FMIC
Injen u/licp
Injen Intake
HKS 272 Exhaust Cam
Walbro 255lph Fuel Pump
Greddy 720 cc Denso Injectors
Greddy Catch Can
XS Mini Battery
Turbo XS TBE w/ Test Pipe
Ichiba Exhaust Manifold
TTP o2 Housing
Forge WGA
Forge DV
AEM Uego Wideband o2
AEM Tru Boost EBC
Justin McGrath tuned
Adam Hennessey built
Shortly after we put in an AEM Meth kit with a Snow Performance SafeInjection wastegate solenoid. Unfortunately when we finally got it on the dyno after Justin’s road tune, we found that it was spraying too much meth (using the large size jet). I decided to hold off on anything over the winter and to get it dyno tuned for the meth (medium jet) when it got warm. I was also having an issue with partial throttle bucking/ surging. While waiting to get in for a tune from Seth I switched the dv to a APS Dual Vent dv, and it totally cured my bucking issues. I also threw in some Buschur Racing shifter bushings and Mynes hood dampers.
Unfortunately I wasn’t able to get a response back from Seth to set up an appt to dyno tune it for meth, so I decided to give CBRD in York, PA a shot. For those not familiar with CBRD they are a Evo/ STI specific shop that has tons of experience working with Evos, and are currently building a shop time attack Evo IX. Anyways, after talking with Chad we set up a date to do the tune, and I also decided to finally add a HKS 272 Intake cam while I was there.
The tune went pretty well, however Chad felt that I was missing about 25hp and tq. He recommended that when I got back home that I change out the spark plugs, change out the meth (the 50/50 meth mixture had been in my meth tank since last fall), search for a boost leak, and to run some logs after. Well I did all this, and did find a pretty bad boost leak. I sent the logs to him and he said that there is some room for more timing. At this point I am still waiting for him to send me the updated map.
Shortly after getting all this straightened out I decided to finally look into going with a bigger turbo. After talking with Chad once more we decided a 50 trim would be my best bet. Unfortunately after doing some research we found that for me to fit a 50 trim in there I would have to change out the intake, intercooler pipes, exhaust header, etc… I wasn’t too thrilled to be paying another 2k to upgrade parts I’ve already upgraded, so I decided to look into a stock appearing turbo from FP. It didn’t take long before I decided on the FP Red and placed my order for a ported Red with head studs from Buschur Racing. I also order a new O2 housing with a divorced dump from evopowermods.
So that’s where I am at now. Waiting for the turbo, O2 housing, and head studs to come in then I am heading back down to CBRD for install and retune.
Current mods (Updated 8/20/08, and format copied from Justin):
Intake
-Injen Intake
Exhaust
- Ichiba Exhaust Manifold
- Turbo XS 3" TBE w/ Test Pipe
- EPM O2 Housing w/ divorced wastegate to atmosphere
- Forge WGA
Chemical Intercooling
- AEM Methanol Injection Kit
- Snow Performance SafeInjection WG Solenoid
- VP Race Fuels M1 (50/50)
Fuel
- Walbro 255lph Fuel Pump
- Greddy 720 cc Denso Injectors
- Denso Iridium 1 step colder plugs
Engine
- HKS 272 Cams
- ARP Head Studs (Ordered)
Forced Induction
- FP Evo Red (Ported) (Ordered)
- Injen FMIC
- Injen u/licp
- APS Dual Vent DV
Monitoring
- AEM Uego Wideband o2
- AEM Tru Boost EBC
- Autometer Steering Column 2 Pod Gauge Mount
Suspension
- Blox Front Engine Roll Stopper
Misc.
- Buschur Racing Shifter Bushings
- Mynes Hood Dampers
- 35% F/18% R window tint
- Greddy Catch Can
- XS Mini Battery
- Perrin Shorty Antenna
- Greddy High PSI Radiator Cap
- CBRD Tuned
Planned for this winter:
Exedy Twin Disc Clutch w/stainless steel clutch lines
JDM Evo IX SE Front Lip
Future mods next spring/ summer:
Helix DNA Sport Coilovers
Whiteline Bump Steer Kit
Whiteline Front Roll-Center Adjustment Kit
Works Rear Adjustable Sway Bar
Works Rear Strut Tower Brace
Enkei RPF1 wheels
Cliff Notes: Evo IX with basic bolt-ons, cams, meth injection, CBRD tuned. Ordered FP Red stock appearing turbo, evopowermods O2 housing with totally divorced dump, and headstuds.
Some current pics
) and he is most certainly going to make the trip to come out. BBQ food, beer, and a fire…what else can you ask for I must say!!! I’ll get the details to you soon.
