My car was put back together after an early autumn accident last year. Last few months I have been working on it. Didnt do much but the head was cleaned up and put back on, new distributor, new wires, new rotors and pads, new cv joint, new lower ball joint, new wires blah blah. Im not the biggest motor/techincal person ill tell ya straight forward. The car odesnt seem the same as it was before it was fixed up. Power maybe I dunno? But I was wondering if someone who nkows a decent amount about hondas give my car a nice tuneup and throw me a price ill give ya some money, I jus need someone who knows enough about hondas/enginges and give my car a nice tuneup. Also install a ur crank pully for me Thx- Ben
If you dont have anything to tune with then there is no reason to get tuned, however, if you need someone to check over the car call us and make an appt. and we can make sure that everything was gone through properly.
well, you DID the “tune-up” with the plugs/wires/distributer capr and rotor. only othe thing you can do is have your timing checked and maybe the injectors
valve adjustment, check timing, clean IAC valve, change air and fuel filter, check for vac leaks. Those are all simple things that can help your car out as far as a quick tune-up goes.
