2000 Acura Integra GSR 700+whp Turbo build Part out
Pretty much every part has less than 500 miles on it!!!
• Very clean 2000 Acura Integra GSR Shell, 83k miles, Custom bent and Tig welded 10pt roll cage, quick disconnect parachute mount. Clean title $3000
• Completely assembled B18C1 motor with parts below $3500
• 81mm and 81.5mm B18C1 Blocks with girdles $250/350
• 2/LS cranks Micro polished and balanced $150/piece
• Manley Turbo Tuff rods $350
• CP 9:1 81.5mm pistons with the upgraded wrist pins $300
• Moroso 5qt oil pan $300
• Fluidamper crank pulley. $175
• B18C1 Head port matched and polished $400
• Skunk2 Tuner 1 cams $400
• Skunk2 Tuner series valve springs $125
• Skunk2 Tuner series retainers $125
• Skunk2 Tuner series valves $150
• Skunk2 cam gears $150
• Edelbrock Victor X port matched and polished $225
• 2 sets of ARP headstuds $50/set
• Skunk2 port matched and polished billet 70mm throttle body (vband) $200
• GSR valve cover with AN fitting bungs welded for catch can $125
• GSR 5 speed with Quaife LSD $800
• Competition Clutches Twin Disc $600
• Drive Shaft Shop Level 3.9 axles with ARP extended wheel studs $750 SOLD
• Golden Eagle Scatter shield. $175
• NRG quick release steering wheel kit with Momo wheel $350
• Kirkey aluminum seats and covers $200
• 5 point camlock harness’s $100
• DC sports short shifter $30
• Ground Control adjustable Coilovers with Koni Yellow shocks $700
• Type R rear sway bar with BEAKS mounting kit. $175
• Hasport motor mounts $235
• Full race traction bars $200
• EBC Dimpled and slotted rotors $100
• EBC green stuff pads. $25
• Russell Stainless steel braided brake lines $50
• Mickey Thompson 24.5x8x13 slicks on Lensos $400
• 15" Rota slipstreams with Dunlop Direza tires. $400
• PWR dual core half radiator $75 SOLD
• FAL slimline electric fan. $40 SOLD
• Borg Warner/Bullseye Power S366 with Extended Tip Technology $750
• Full Race Ramhorn exhaust manifold $575 SOLD
• Full Race open dump tube $50 SOLD
• Tial 44mm Wastegate $250 SOLD
• Tial 50mm Blow off valve $200 SOLD
• Custom tig welded 4 inch aluminum Vbanded down pipe $100
• Precision turbo 750hp core Intercooler $300
• Custom tig welded 3" Vbanded charge pipes $125
• T1 racing catch can $200
• Fluid control solutions aluminum 5 gallon fuel cell $375
• Bosch 044’s $190 (brand new)
• T1 racing dual pump hanger (brand new) $100
• RC1200cc injectors $225
• Edelbrock pro flow fuel rail $70
• AEM fuel pressure regulator $70
• Moroso Fuel pressure gauge $25
• Hondata S300 w/ecu controlled boost solenoid $500 SOLD
• MSD pro billet distributor and Coil $500
• MSD spark plug wires $25
• NGK Iridium plugs $20
• GM 3bar map sensor $40 SOLD
• Triple pod steering column gauge mounts $25 SOLD
• AEM Uego wideband. $100
• 55 gallon drum of Rocket Brand Racing fuel E85 $300
Over $17,000 worth of parts!!!
[ATTACH]22049[/ATTACH]
