ok so i want to get a bigger turbo for my teg but i dont know what iam getting a bigger intercooler and moving up to i think 3in pipe’s from 2in i dunno what turbo i should get i need your help what would be a good size or whatever i want to run around 500-600hp here is my set up now iam at around 400+ on 12psi lmk what you guys think i should get
Motor/Tranny:
-1997 JDM Integra Type R
-Hone and Bore .020"
-CP 81 1/2mm. Pistons
-Eagle Connecting Rods
-ARP Headstuds
-Golden Eagle Block gaurd
-New in 2005:
(OEM valve seals, Honda gasket set, Water pump, Oil pump)
-RC 750cc Injectors
-Edelbrock Victor X Intake manifold
-Edelbrock Fuel Rail
-Holley fuel pressure regulator
-B&M Fuel Pressure gauge
-Hasport Extreame Motor Mounts
-Walbro 255 High pressure fuel pump
-ACT Springless 6puck clutch heavy duty pressure plate
-New C/V Shafts
Turbo/Cooling:
-Turbonetics T3TO4E turbo (57/60)
-Drag3 Exhaust Manifold
-Drag3 Air intake
-HKS SSQ Blow off valve
-Tial 38mm Wastegate
-Drag 3 spearco bar and plate intercooler (core is 22x7x2.5 inches. inlet is 2.25 and outlet is 2.5 inches. total width of intercooler with cast endtanks is 27 inches.)
-KTeller 3in. stainless steel exhaust
-3in. magnaflow muffler
-Custom stainless turbo piping by Hybrid
-Nitrous Oxide Pre cooler system
