A lot changing with my car shortly, so its a fresh start…
I got a VG30ET back in it, with my FMIC setup, 3" Certified Muffler turbo-back, one of our gutted plenums and Z32 brakes going on shortly. Car is running/driving again with the VG30ET, but I’m still waiting on some parts.
Details:
'86 Factory-Turbo chassis, no rust of course…
Engine/Engine Management:
'84 VG30ET
'87 A/B series Crank Pulley, Water Pump pulley & PS Pump
Sentra 100A Alternator
'88T Injectors/Rails
'84T ECU
PRW-2 Ignition Transistor
'95 CAS
NGK Plug Wires
Z32 Fuel Filter
Walbro 255LPH HP Fuel Pump
Gutted Plenum /w Removable Lid
FMIC Setup /w 2.5" pipes
CM 3" Turbo-back /w test pipe
MBC @ 12psi
Ported Turbo-Automatic oil pump
SLC PurePlus 2 Wideband
Drivetrain
South Bend DXD Stage 3 Daily clutch (240mm, 530ft-lb rated)
FS5W71C (need to find another 30A…)
'87T CLSD rebuilt with additional clutches and shimmed
Suspension/Steering/Brakes
88T Front hubs
88T Front Rotors
88T Front Calipers (temporary)
Poly Swaybar Bushings (Addco/Prothane mix)
Poly Zenki Tension Rod Bushings (temporary)
Billet Steering Knuckles
Best $25 I ever spent, completing my set of 16x8 -10 starion wheels!
Gonna be awesome once my proper suspension parts come…
I decided to put the old straight pipe back on…but I forgot Certified Muffler failed entirely when they bent this one for me…so it hangs way too low. Need to get the car on the lift and make it sit up right.
The Ronal R9s are more-so just spares/extras…they’re only 7" wide so they’re meh to me, but 80s as fuck…a bit too euro though. I’m hoping to sell them and just get another set of starquest 16x8s or 16x9s
