Well i have decided to go with another setup and im testing the water to see if anyone is interest if not i;ll just keep it.
Im looking to get $700 for everything here is what is included
this kit is a complete kit for a returnless style fuel system.
here is what is included.
10# bottle painted silver
all stainless steel lines
Fuel powershot soleniod
nitrous super powershot solenoid
Intmidator Purge kit
Bottle heater
Fuel pressure switch
rpm window switch.
ngk tr6 spark plugs gapped at .035 for nitrous. 8 of them
all fitting and adaptors
100 shot jets and like 2 more jets i dont konw what size they are.
its a good way to add some good power for alittle bit of money.
Ill give ya $300 … … have to low ball ya cause it’s a put together kit
$300 you can have everything except, fuel pressure switch, rpm window switch, purge kit, bottle heater, and spark plug let me know.
if you think about it every nitrous kit is a put together kit. they come in pieces and parts lolz. and its nothing is better then a put together kit!
how about $300 and you throw in the $20 fuel switch and the purge or heater
that fuel pressure switch is brand new with box and adaptor that ran me a total of $70…i still have the reciept. and if you wanna do $480 [that is the lowest i will go] i can do the fuel pressure switch and purge.
$550 you can have this:
the orginial kit wet system
Purge kit
preset rpm window switch
ngk spark plugs
for $400 would only give you the orginial kit no extras like the purge, bottle heater rpm window switch. ngk spark plugs, fuel pressure switch
Everything is NOS brand not any cheap stuff.
how much for the purge noid?
looking to get $100 for the purge its the led kit. its 130 on ebay. retails fors
$230 Its brand new in box i only test fitted the soleniod and fittings.
nvm
throw me a offer. if you think that too high
no, dont need led kit. :lol:
The led is only a tip it can be used or left out its the same as a regular purge with the led tip which is removable.
Bump this kit is basically a universal kit. if you car has a fuel pressure of about 43+ psi you will be able to run it. or else you will need to upgrade your fuel system. thanks
Pictures?
here they go right now:
the bottle has some acteone on the paint so you will need to repaint it. So new price is $650 let me know thanks the car was never sprayed becaues i havent had anytime. and want to go a different route.
How much would you want for the purge kit and plugs
whoa forgot about this thread hahah…plugs and purge i’ll let go for $110 let me know thanks
NEW PRICES!!!
Single Wet Fogger
All the stainless steel lines-feed line, nitrous line, fuel line,
the fittings.
it also comes with 100 shot jets and like two other jets. i dont konw the exact shot size.
Powershot Fuel soleniod
Super Powershot Nitrous soleniod
10lb bottle painted silver
$250 picked up or $285 shipped
Bottle Heater For $70 picked up $80 shipped!
