Well i’m trying to move some of the parts/projects collecting dust in my garage due to my extreme lack of time from being active duty in the military stationed in DC. The majority of these parts are what I’ve collected with the intent of doing an SR20DET swap on my AE86 coupe.
I have two SR’s (both OBD1) that i’m selling, one is a very clean Red Top long block minus intake/turbo manifolds, cam position sensor etc with Crower 264 cams. The other is a complete Black Top long block with w/BAD BEARING/BOTTOM END but has intake/turbo manifolds, and all accessories including good turbo and 10lb flywheel. No engine harness, does have coil pack harness.
Obviously I was planning on swapping all the accessories off the Black Top onto the Red Top to swap into my AE86 but as i said before i don’t have the time.
Would like to sell both motors together but i’m open to offers.
SR20DET Red Top:
-Shaved Valve Cover
-Head has been gone through
-Crower 264 Cams
-New Alternator
SR20DET Black Top:
-Bad Bottom End (still ran with a knock when pulled)
-Good Head
-10lb Flywheel
-Aftermarket Turbo Elbow
-Blitz Intake w/MAF
I also have a set of mounts that i had made by a member on Club4ag to put the SR20DET into the AE86 which are powder coated purple (not perfect coating), as well as a custom drive shaft for SR20 to Celica Supra “F” Rear end in AE86 made by Shaftmasters in Michigan. Drive shaft is rebuildable.
Both SR20DET’s: $1700
SR20 RWD Trans with crossmember: $250
SR20 into AE86 swap Mounts: $350
SR20 into AE86 (“F” Rear end) Drive Shaft: $400
If all sold together: $2500
I would also consider partial trades+cash for a decent 220V MIG welder
This is pretty much all the major components to doing an SR swap in an AE86, minus the harness and rear end. I don’t NEED to sell but it’s going to take me an astronomical amount of time to complete the swap with how little free time i have so I’d rather someone else can enjoy it.
Feel free to text or call me anytime, everything is in Fairport, NY.
Alex
(585)490-1307
(I am home Fri 21-Sun, and most likely October 5-7)
---------- Post added at 04:33 PM ---------- Previous post was at 04:00 PM ----------
Pictures added, just to clarify the motor with the valve cover that says “Nissan…” on it is the one with the bad bottom end but includes all accessories.
