I have a ton of stuff, probably will take me a full day to get pictures/price/upload/post everything so i’ll break it down into 2 parts. First will be just universal stuff not specific to 240/SR since i’ve already gathered all that info to post other places and later on i will update this with all my 240/SR stuff, or at least some parts to start.
I AM LOCATED IN WINDSOR
Borg Warner/Bullseye S366 Turbo
Never used.
Divided T4 Outlet.
Believe it’s a .9x A/R turbine.
Comes with oil return flange/gasket and turbine vband outlet/clamp
$1000
Aeromotive Eliminator Fuel Pump
Used but in good working condition.
Comes with inlet and outlet fittings (Believe -10, need to verify)
$380
Aeromotive Compact FPR
Comes with -6 fittings
$110
Aeromotive Fuel Filter
Used. Don’t know the part number so no idea on micron filtration etc.
Comes with 2 -8 fittings
$65
Trick Flow Fuel Filter
New in box.
Part number TFS-23005
$60
Earl’s -4 Filter
New in box.
Part number 230304ERL
Great for turbo oil feed.
$25
K&N Air Filter
New in box.
4" Inlet, 5" in length, conical shape
$35
MSD Wire
New in box.
8.5mm Super conductor plug wire
25ft.
red
$40
MSD Boots
4 Straight boots
4 90 degree boots
$20
2 - XO Racing Knockoff Wastegates
New.
44mm
Believe there is some springs that come with it.
$50 each
Greddy RS BOV
Have no idea where I bought this, I can’t say it’s new with 100% certainty but it doesn’t look like it has ever been used.
New gasket
No flanges.
$120
Cooling Mist Meth/Water Injection Kit
Used (Barely)
Comes with all the parts, some misc. hoses and extra injector nozzles. If interested i’ll get a break down of every piece.
$230
Autometer Carbon Gauges
Used, faces in great condition.
Boost, Oil Temp, Oil Pressure.
All gauges come with the needed fittings, senders, sensors. Only thing missing, boost needs new hose.
$40 each
Blitz FATT DCII Turbo Timer
Used, good working condition.
$45
Professional Products Mustang Throttle Body
New, never used.
3" inlet
Comes with all gaskets and misc parts.
Also have used mustang IACV that fits throttle body if needed.
$110
DMH Electric Exhaust Cutout
3"
Comes with Y pipe, block off plate, cutout/switch etc.
Does not come on the downpipe pictures
$130
Catco High Flow Catalytic
$SOLD
Innovate Motorsports LM-1
Used, still works perfectly
Comes with everything needed including bosch wideband o2 sensor.
$100
Precision Turbo Intercooler
New. Bar and plate design.
Bought this as a core started building my own end tanks and mounts, never finished.
Core Size is 4.5" deep, 12" tall, 16" across.
It is mostly complete minus a piece of round aluminum welded to endtank for IC piping
Has a flange welded on to fit the greddy BOV
If anyone is interested in this I will gladly help with LIGHT modifications of the endtank & welding, welding of the pipe connector at endtank and welding of brackets to fit your vehicle.
$315
Summit Linelock
Used, works.
Missing all the little crimps and switches that would come with it
$20
Precision Turbo 1000cc Injectors
$SOLD
DSM Injector Box
Used obviously
$10
If you’re interested in anything PM me, don’t post here. Thanks.
