Problem solved,
Ended up being a leaking injector seal that only caused the issue below 1000 rpm
Hey guys so I have been in this on going battle with my car, I have done almost everything to rule out that everything is working properly.
HOWEVER TODAY for the first time after resting the ecu according the FSM I rechecked the codes and got Code 11 ( i also have codes 21 ignition and 34 - knocksensor )
The knock sensor is brand new
I have a brand new wiring harness and everything is hooked up correctly I have been speaking with yury from wiring specialties for almost a month now sending him pictures the whole deal
Now people with this code before or anyone with experience with this code did you have to replace the CAS?
The Problem:
The car has perfect 14.7 afr at anywhere above 1000 rpm runs great
BUT as soon as the car falls below 1000 RPM whether it is cold or warm, the AFR’s shoot through the roof
18:1 and higher
I am certain that this is what it is but I would like anyone elses opinion before I make a $400+ investment
Thanks guys really hope I can get my car back on the road
Jay
Here is my other Technical thread on the current issue
http://www.son240sx.org/showthread.php?243817-SR20DET-Running-Extremely-Lean-at-idle
