I’ve had this motor fogged and properly stored in my garage waiting for a project that never happened. I purchased it from user PAC1085 (great guy if you don’t know him) last spring. The setup is very well done and you can tell Phil took his time with everything. A summary can be seen at his blog here: http://blog.no-skill.com/
I also have videos of the engine running and all documents for the build. Now, on to the details:
2008cc AEB Stroker $1900 OBO, picked up.
(~20,000 miles since build)
AEB head casting from a 97 1.8t
- Head consists of stock components, and was rebuilt by Drakes.
- Installed new cam chain tensioner ($$) and chain at same time.
058 block casting from a 98 1.8t
-Machine work done by Proformance, assembled & grinding for rod clearance by Phil.
-Block was sonic checked (I have the printout) and bored/honed with a torque plate
-All of the gaskets and most of the bolts were replaced with new when the engine was built.
Components:
-Forged OBD-I ABA crankshaft
-Wiseco custom forged pistons (8.5:1 CR) with ceramic coated dome/coated skirts. I have the custom order spec sheet.
-ALT head gasket
-SCAT 144 / 20mm Rods w/ ARP pro series 2000 alloy bolts
-Main bearings, rod bearings and I/M shaft bearings coated with swain tech ppm
-I/M shaft lightened, balanced and clearanced for stroker by Jarod @ SCCH-Heads
-ARP Main Studs
Full-Race T3 Exhaust Manifold - SOLD
http://www.full-race.com/store/turbo-manifolds/audi-vw-1-8t-longitudinal-t3-prostreet-turbo-manifold.html
Holset HX40 super turbo with Bullseye HX40 hot side - SOLD
http://www.extremepsi.com/store/product.php?productid=23484
Treadstone TR11 Intercooler - SOLD
http://www.treadstoneperformance.com/product.phtml?p=2035&prodname=TR11+Intercooler++560HP
Tial V44 wastegate - SOLD
Tial 50mm Blow Off Valve - SOLD
2.8 throttle body (new) $50 + shipping
(4) Siemens 870cc Injectors $140 + shipping
I can provide pictures on request. Thanks.
