I have a 2000 Passat v6 with a blown engine. I want to swap it out myself with a good one, but i’ve never done this before. I noticed that the Bentley manual should help out a ton, so i was wondering if anyone has one that i could borrow, or have an online copy that i can have.
you can pay by the day for the online version($25 for 3 days I think?), or like $75 for the hard copy. I don’t have any right now, esp for a passat… but that should get you started.
doesnt the A6 mount the engine longitudinally? the passat is a VR6 mounted transversly, correct?
to the OP, just buy the bentley, you can always sell it when you sell the car. i bought one new for my old b3 passat for like $45 then sold it when i sold the car for $40 used.
Check out VWVortex.com under the technical forums, there has to be an online tutorial there. I got one for doing a timing belt and it was done VERY well by the poster, tons of pictures. You have to take the front of the car off which takes about 15 minutes, from there it is pretty simple, not any specific “tricks” The only thing thats lame about Vortex is the search function is TERRIBLE
thats why my statement had a ?? on the end of it, i wasnt sure. all my vdub experience is with the older (cooler) ones. my passat was a b3 with an o2a.
as long as you are just removing and replacing the engine with one of the SAME year, you shouldnt need a manual. i know vw likes to change things year to year or even midyear though, so a manual might not be a bad idea.
Once the bumper is off it should be pretty easy, I’ve had mine pretty close to ready to pull on a few occasions, I can’t imagine the wiring harness and the tranny are that hard to take off.
not gonna lie, it’s a shit job on the floor… srsly… if you’re worried yank the engine and trans together and mate them on the ground. just pull the transmission mounts off the tranny and it’ll slide out. pull the pcm box lid and yank all the connectors and the wiring harness goes with the engine to be swapped onto the new engine before it gets stabbed. good luck
