Water pump alt. bracket Help
I just bought a Weiand water pump for the s10 its a long style pump thats going on a 350 v8, I was looking closer and their is no Holes for the passenger side upper Alternator Bracket on this pump, Does any chevy’s with v8’s come with a upper passenger or driver side Alternator Bracket that doesnt bolt onto the water pump? i need to find something to work, summit and jegs, want a arm and leg for the Bracket!!
how about using a low mount alt bracket?
x2
http://store.summitracing.com/partdetail.asp?part=HLY-64221&N=115&autoview=sku
it is kinda pricy
i really didnt want to spend that much for brackets!
If I remember correctly the monte carlo has the long water pump with pass side alt mount, do you heads have the provisions for 3 acc. holes in the heads on that side if they do just pick up a monte alt, and a bracket that cost like 10. i might even have a few around. also r u running a serp. setup?
i believe the heads do have the 3 bolt holes and iam running a v belt
then thats the exact same setup as the monte ss, which will work, stock was a 305 but same head patteren and long water pump just an option to throw out there.
i read it wrong,85 thru 87 f-body had what u need also
