Hey,
I have this problem. Sometimes(not always), when I start my car, I hear a noise, almost like if my bearing clutch was finished but I know for a fact that it’s not since I changed it this weekend(+ clutch). Sometimes the noise appears when I change my gear, but only when I press the clutch. Any idea
THROW OUT BEARING…100% SURE
What is the difference between the clutch bearing and the throw out bearing ? Aren’t they the same ? It was spinning like a charm. The problem persists even if I changed that. So my guess is that it’s not that. Might it be something else ? Thrust bearing ?
I’ve seen this thread many times…same solution every time.
Varun’s right, it’ll be the throwout bearing.
