copied and pasted right out of my list, i know im forgetting stuff as i go, so i figured id just let you guys read thru and remind me now.
general observations are welcome, car is a ls1 firebird if anyone wants to make vehical specific observations. after i get a base list, ill be breaking it down item by item to specify sizes / lengths ect
tubing: $414
304 stainless:
(1) 2" 180 degree
(3) 2.5" 180 degree
(3) 3" 180 degree
mild steel:
(2) 2" 180 degree
(2) 3.5" 180 degree
exhaust:
.truck manifolds - ebay - $120
.truck manifold gaskets
.manifold flanges - stainless works FLNGCDH FLNGCPH - 70 + shipping
.manifold flange gaskets
.manifold flex pipes - vibrant - VIB-4556 $41.16 ???right one???
.NBO2 bungs
.Turbo - $1050
.turbo flanges
.oil lines and fittings
.water lines and fittings
.Wastegate
.Wastegate flange’s
.wastegate gaskets
.wastegate flexpipe
.dump v band - turbo
.dump v band - rear
.cat back
Intake:
.filter -
.couplers
… filter pipe to turbo - 4"
…turbo to intercooler pipe - 3"
…intercooler pipe to turbo - 3"
…intercooler to pipe - 3"
…pipe to throttle body -???"
…TOTAL - one 4" & four 3"
.BOV
.Intercooler - 24"X12"X3 - $160
.tbolts
… filter - 4" x1
… filter pipe to turbo - 4" x2
…turbo to intercooler pipe - 3" x2
…intercooler pipe to turbo - 3" x2
…intercooler to pipe - 3" x2
…pipe to throttle body - 3" x2
…TOTAL - six 4" & eight 3"
.vac lines and fittings
.Boost Controller
Fuel / tuning
.fuel pump - 225
.injectors $425.
.fuel lines
.fuel press reg
.adapters of any sort ???
.tuning software
engine & tranny parts:
.oil pump - internal
.oil pump - external
.engine oil cooler
.tranny oil cooler
.oil pump lines - external
.oil pump wiring / switch / relay
.oil catch can & fittings
.serpentine belt - a/c deleat
.new crank bolt (ARP $30)
.front crank seal ($23)
.poly engine mounts
.2 bar map - GM PN 12580698
gauges:
.wideband - 265
.boost
.oil pressure
.tranny temp
.engine oil temp
.fuel - mech on fpr
.gauge pod
.wiring (pos, neg, + multiple colors for signal wires)
Steel stock
.alternator mount
.turbo mount - angle iron
.intercooler mount
.intercooler shroud
.piping gussets
.piping brackets
Bolts:
.head -> manifold
.manifold -> y pipe
.Y pipe -> turbo
.turbo -> dump tube
.wastegate
.turbo support bolts
.piping mounts
.intercooler mounts
Other Parts:
.rear LCA relocation brackets
.panhard bar relocation bracket
Random Supplies & Gaskets:
.Coolant
.oil & filter
.RVT gasket maker
.loctite
