This is the second time that my clutch diaphragm has cracked. It cracked the same way as last time 3 fingers apart on the diaphragm. Balance shafts were aligned porperly, new clutch parts, the plate was balanced. Here is a pic of the last time it happened.
I was running the KEP with the 930 disk then it broke and I switched to the clutchnet 6 puck copper/ceramic. I was using the stock flywheel but now I got a 6lb fidanza:)
And you’ve cracked both setups or just the KEP one?
[/quote]
yup both setups
although I got a brand new clutch fork here($400:( )and it seems that the fingers are a little shorter than the one that was in my car like 1mm so that could be the problem
