Where to buy fuel injector collars.
Anyone know where to buy fuel injector collars in toronto if not here, anywhere else in Canada.
What’a a fuel injector collar?
There’s only two main rubber pieces on the injector. The o-ring which
is at the tip of the injector nozzle, and the larger rubber o-ring which
usually sits on your manifold.
A fuel injector collar is a round piece of metal like a donut that you use to adapt certain kinds of aftermarket injectors to your stock fuel rail.
Oh you mean the little clips? Like this:
This is from my MSD top-feeds on a custom rail
http://240sx.cubicdesign.com/images/misc/fuelrail1.jpg
Larger Sidefeed Injectors tend to be taller than stock so Injector callers
(spacers) are needed for the Injector caps to properly seat ontop of thr injector.
Here’s what thet look like:
http://images.google.ca/images?q=tbn:CCgLUc9UtUoJ:www.superiornissanmotorsports.com/store/images/SrdICollart.jpg
Yup that’s them. So any info on where to get them. Btw I will be using rx-7 injectors so would the ones you use on the sard injectors work for these as well.
Rx-7 injectors are top feed though… custom fuel rails?
No I did some research and found a forum that gives a detailed account on how to use them. The only thing you need are the collars.
im thinking i might need these too since im getting some supra injectors.
i suppose it shouldn’t be hard to make them. they are just spacers.
